So, lately I have smelling a strong synthetic burn when I am getting of the interstate. This isn't an oil burn, so the only thing I can imagine it to be, is transmission fluid, as its that strong. I have not been getting any leaks on the ground, so I have been unsure of whats going on.
Saturday, I decided to level out the car, and check the fluid. I am not low, but I do believe it may have too much in it. I took out the top drain plug, and it came spilling out. Not a whole lot, but instead of letting it get all over the garage floor, I put the plug back in. I only put 3 QTs in when I did my clutch replacement, so it can't be over filled that much.
My question, if it is over filled, will I have this issue for a bit, and will it go away? Should I get it level again, pull the plug and let it drain out until it stops?
Thanks for your time and responses,
Nick
Nick
