FINALLY AFTER 2 MONTHS OF NOT WORKING ON MY CAR,I ADJUSTED THE SHIFTER AND BLED THE BRAKES ON MY STANG. JUST WHEN I WAS ABOUT TO MAKE A TRIP TO THE MUFFLER SHOP I REMEMBERED THE CONVERTER IS A 11" 2500 STALL. I HAVE A 302 WITH AN AUTOMATIC C4 WITH A SHIFT KIT.I ALSO HAVE A B&M ALUMINUM DEEP PAN.
NOW IM REVING 2GRAND BEFORE I START INCHING AWAY.. I STILL HAVE A STOCK CONVERTER FROM MY OLD C4. I CHOSE THE STALL BECAUSE IT WAS RECOMMENDED BY A FRIEND WITH THE SAME APPLICATIONS. HE WAS RUNNING A 91 5.0 302, C4 AUTO TRANS AND SAME CONVERTER AND IT RAN FINE.
NOW SHOULD I BUMP UP THE TIMING A BIT MORE OR SWITCH OUT THE CONVERTER? ANY SUGGESTIONS WOULD HELP!
