Transmission / Radiator (cooler) return lines
Discussion in 'Mustang II' started by Gunmetal5oh, Jul 8, 2004.
  1. Gunmetal5oh Founding Member
    Apr 11, 2002
    Message Count:
    1,095
    36
    USA
    The metal tubes that come out of my radiator got bent to hell and I would like to replace them. Would napa or o'reilly carry them?
    The rad has a b&m cooler mounted on it also.
    Do I call a radiator shop? :shrug:
  2. cobraii351 Founding Member
    Jan 10, 2000
    Message Count:
    1,102
    36
    Altoona, PA
    Someone post this in another thread but it will work for you as well. That or cut off the bent portion and remake the rest yourself.
    http://www.classictube.com
    Tim
  3. LedZ 5.0 now you have my pea brain going in circles
    Apr 1, 2004
    Message Count:
    207
    My lines on my 78 were damaged about 12" from the rad. I bought some new lines from NAPA and cut to the correct length with a tubing cutter than reconnected to the existing trans lines with brass compression fittings. I didn't see the need to replace the complete trans lines with new ones because they were still in good condition from the damaged section to the trans.
Share This Page
