Tremec 3650 3-4 shift
Discussion in 'SN95 4.6L Mustang Tech' started by 4.6modular, Dec 11, 2003.
  1. Hey everyone I'm new here and wondering if anyone has had trouble shifting from 3-4th at high rpm's. The other day I was passing someone. Shifted from 3-4, released the clutch and I heard a big bang. After that has happened it still continues to shift normally. Is that problem shift forks or sychros. :shrug:
  2. Wow...never had that problem, 3 to 4 and 4 to 5 have always been very smooth for me. I'd much rather have your problem than the clunky 1 to 2 shift everyone else seems to have with the 3650. I'm curious as to what it would be, I doubt it was the shift fork or synchros because if they were it would do it every time.
  3. I would definately get that checked
  4. Maybe it wasn't all the way in fourth when you released the clutch?
  5. You probably let the clutch out to early before the gear was fully engaged. If it shifts normal then I wouldn't worry to much about it. If there are symptoms that a tech could see then I would bring it in otherwise they will just say everything is fine and send you on your way.
  6. I didn't think about that
  7. The 3-4 shift is my easiest and quickest shift.
