Great numbers!
I had my beast in at the Ford dealer for 4 hours to have them run as many diagnostics as they could run. The dealer sells Cobras, Lightnings, and Saleens. They know about blowers and such so I thought that it would be a good place to bring it. Most dealers would not even open the hood of a blown car. I had some issues with the car when it was new that never got resolved, so I wanted to be sure that there were no Ford related problems before I pursued other avenues.
After 4 hours, they could not find anything Ford related that would cause my "hitching" problem while cruising and the detonation at low outside temperatures. EVERYTHING checked out fine. The mechanic did notice a slight anomaly, however. All of the Ford testing equipment showed no problems, but the Snap-On diagnostic tool would show an occasional miss. Sometimes it would be cylinder #1, then it would be #5&6, etc. He said he never saw that type of thing happen before (difference between his testing equipment). They ran a balance compression test and that checked out fine as well. The mechanic said it was still possible that there could be an ignition problem, but he could not pinpoint anything.
He also said the detonation is definately WAAAAAY too bad! He was very concerned with that. I know what makes it detonate, so I keep out of it. But when it is cold, there are getting to be too many places that it will detonate. The mechanic also reflashed the computer (had to remove chip first). The dealer was very good to me and I felt good that I have found a place that I can take my car when it needs work.
I called Kenne Bell last week about this issue and they said that they would talk it over amoungst themselves and call me back. So far, no call. I think they are stumped.
After seeing this post, I am inclined to find a tuner to see if they can figure out what the problem is. I will still be calling KB to see if they will help me. I did my part in replacing every component I can think of and for bringing the car to a good Ford dealer for 4 hours. Now they need to pony-up to help me with their product. The car should not run this way. It is good to see the good numbers and the good running of the other KB'd cars here. It gives me hope that mine will be fixable.
Oh, the mechanic also said that even thought the coil stress tests showed all good coils, that one or some could still be marginal. He said that I might want to try replacing the COPs with some aftermarket ones. Does anybody know any good brands to get?
The mechanic also checked the plugs and said that the car was running too lean. Because the KB chip controls that, he can't do anything about that. The tips where white.
With all of that said, do you other KB guys get ANY detonation or any hitching at all? The hitching occurs while cruising at between 30 and 50 MPH. The detonation occurs mostly when the outside temp is lower than 55 degrees. Removing the EGR vacuum hose seems to stop the hitching. All EGR components have been replaced.
The KB blower is a good product, but KB needs to step forward to help those of us that do not live in the tropics. Whenever I call them and they say they will call back, they never do. I don't know if they are just plain stumped or if they don't really care to call back. I have resisted going to a tuner because of the expense. It will cost me $600 to have it done at Kennedy's. That may be my only option if I can't get this resolved.
I would like to point out that KB said that nobody else could tune a KB blower better than themselves. That does not look to be true anymore after seeing these numbers. I am impressed with that tune.
