94coupe 15 Year Member Oct 6, 2013 138 0 17 Calgary ab Aug 3, 2014 #1 Aug 3, 2014 #1 have no power to signals on my 84 gt....if I pull the wheel of is there a way to check??...ive checked fuses flasher.....but no lights even on dash indicators??? thanks cam
mikestang63 SN Certified Technician Aug 27, 2012 11,600 9,192 214 In the garage Aug 3, 2014 #2 Aug 3, 2014 #2 Check the mutlifunction switch located on the turn signal base. They are known to fail
cdurbin 5 Year Member Jul 27, 2012 563 108 64 North Charleston, SC Aug 4, 2014 #3 Aug 4, 2014 #3 mikestang63 said: Check the mutlifunction switch located on the turn signal base. They are known to fail Click to expand... Try wiggling the key in the ignition and see what happens. Mine did that and it was a bad ignition switch
