For a car that has been sitting for an extended period of time, if you are concerned about sticking rings take out the plugs and squirt a little oil in each hole. Disconnect the coil wire and ground it then tap the key a few times to turn the car over and crank without spark. If you want to be ultra safe prime you can the top end by removing the distributor and either use an old distributor shaft or the tool on a drill. After a few months of sitting your lifters may have bled down a little. I would also change the oil and filter after you warm the car up as the oil has been sitting for a few months. Hope you put some stabil in the gas before you stored it, or you should dump the tank and put fresh gas in it before you start it up. Bad gas can wipe out injectors, fuel pumps and such. Let the car warm up and idle for a good 10 minutes or so and check all the gauges and levels. Gaskets and hoses have a way of drying out when sitting for a while so check for leaks too.
