To start I'm currently deployed and need to sell this car or part it out, But I will not be able to ship parts out until MID DEC. Or you can come to the car and take the parts out yourself. But here is the list of parts available. You are welcome to stop by and take a look at the car at any time, car is located in Fayetteville NC, PM for address. car is garage kept for anyone wondering. You can buy the whole car and everything in it for $9500 or BEST OFFER, it will drive away and will need a jump, it is also untuned. NO PRICES FOR PARTS, MAKE ME AN OFFER...this car must go, taking bottom $$$ for it all. PICS COMING IN A FEW HOURS 2001 MUSTANG GT (red) 50k miles HPP Twin turbo kit (Twin 57mm Garret t3/t4) Bullit Rims deep dish (chrome) Front tires 275/35/17 Nitto fronts (80% tread left) Rear tires 315/35/17 Nitto drag radials (95% tread left) MOTOR 281 Fastlane forged Motor 9:1 compression 03 cobra crank Fastlane stage 1 ported heads Turbo Cams Stock PI intake manifold 75mm Throtle body Plenum HPP Twin turbo kit (Twin 57mm Garret t3/t4) 3in Downpipes from Turbos 36x12x3 intercooler Twin 57mm Garrett turbos Apexi BOV QA1 Tubular K-member SCT multi tune chip SCT tune selector ( to switch between pump gas, race gas, and whatever other tune you might want.) SCT BA 2800 MAF FUEL 03 cobra fuel tank (baffled) Dual Ford GT fuel pumps Aeromotive inline fuel filter (100 micron) 8an fuel line Aeromotive fuel rails 60lb injectors Zone 5 FPDM Y fuel block from fuel pumps to 8an fuel line Aeromotive Fuel Pressure Gauge SUSPENTION / TRANSMISSION QA1 Front adjustable coil overs QA1 Rear adjustable coil overs 3.75 gears 8in rear end (welded tubes) TA Girdle UPR upper and lower control arms UPR upper contorl arms (not in car) 5 speed from 99 Cobra Spec stage 2 clutch Cross drilled/slotted rotors Aluminum driveshaft BODY/INTERIOR Saleen style front (not painted) Saleen Style rear bumper (not painted) Cloth interior Cobra R hood (black) Bullit side vent deletes Pillar 3 gauge pod Steering column dual gauge pod GAUGES Aeromotive Boost gauge Oil pressure gauge ( electrical sender) Aeromotive Fuel pressure gauge AEM Air/fuel gauge Water temp gauge Oil Temp gauge Greedy Profec B boost controller mild tune on pump gas it should push 600 rwhp On race gas it should push 700 rwhp The BAD Needs a tune Needs a paintjob Still needs another 200 break miles on new motor Needs adapter from transmission to speedometer, aka speedometer does not work. Needs Either x piper or H pipe and catback....downpipes fromm turbo come from turbo to about behind the front tires, and its VERY loud. Taking best offer on all parts or you can get the car and everything in it for $9500 The car is located in Fayetteville NC, near FT Bragg.
whats the mileage on the body? what about the mileage on the mods, like the motor transmission and turbos?
i hope everything is going ok over there and ur staying safe bro.. when you get a chance just give me an update on the mileage on the body motor and performance parts.
hey man, im about 45 mins from fort bragg, pm me a price on the hood and all suspension. also if the deal falls out on the wheels, them too. thanks Lee
