Twin Turbo suggestions for a 408w
Discussion in 'Power Adders' started by zrchobbies, Sep 27, 2007.
  1. zrchobbies New Member
    Oct 27, 2006
    Message Count:
    Alright. and before you say it. I know I am currently looking on turbomustangs.com. Frankly though some of those guys are a bit s**ty. This is what I have: late model windsor block, nodular cast crank, forged i-beams and Kb forged pistons. pro topline 200cc heads compression at 9.5:1. I am looking to do a twin install in my notch. I hade originally decided nitrou was the route for me and after many months of haggling from a friend he has convinced me otherwise. I would like to get some suggestions from anybody as to what would be a good pair of turbos to make somewhere in the realm of 650 hp. I know thats stressing a stock block quite a bit, but I will be running lower boost pressures until I upgrade to a better shortblock. My main goal no is to get it in and do some tuning and get it close to where it needs to be. This is a street stip application that will see a lot of street use as well as track and will likely be driven to the track.
    Thanks
  2. zrchobbies New Member
    Oct 27, 2006
    Message Count:
    I would like for the boost to come on as low as possible as well. Being a stock block I really don't want to turn in up real high. No more that about 6500
  3. millhouse Founding Member
    May 14, 2002
    Message Count:
    2,074
    46
    I'd say twin 60-1's would probably be your best bet. They will easily support your current and most likely your future h/p goals.
  4. zrchobbies New Member
    Oct 27, 2006
    Message Count:
  5. fastranger347 New Member
    Nov 5, 2006
    Message Count:
    71
    two 61mm t4's with a .84 turbine housing with a p trim wheel, im making about 600 with a stockblock 347 and i havent split it yet, so your 351 should be able to make 700+ without issues
  6. Daggar New Member
    Jul 20, 2004
    Message Count:
    5,559
    111
    Why twins? Is it just for the kewl factor?
    Turbo systems are so much better in the efficiency department these days that I just don't see the benefit from the additional hassle.
  7. phast69 New Member
    Jul 31, 2002
    Message Count:
    61
    Agree...I'd just go w/ a large single. Twins means your gonna have more piping, more **** to cool, more **** to break, etc.....
    By all means twins look cool but now a days a single can work just as well.
    Good luck bro. Whatever route you take...post pics!!!
  8. millhouse Founding Member
    May 14, 2002
    Message Count:
    2,074
    46
    The biggest downer with a twin setup is the extra cost of a turbo. Figure on having to spend a good 1/3 to double the amount of the cost for the two turbo's over a single.
    Besides that, it's really not that much more to plumb. On a single setup the cold side is far easier to run, while the exhaust side is more complex. A twin setup while having a more complex cold side has a simpler exhaust setup, as you simply run the pipes from the turbo to the h-pipe.
    For me it came down to availability of junk yard turbos (turbocoupe turbos seem to be far easier/cheaper to come by), symmetry and just cool factor. Plus there is the extra benefit that for some reason people see a single turbo setup and think…cool!. When those same people come across a twin setup, they shout…holy shi%t and then comes the "gathering".
  9. Decipha New Member
    Aug 22, 2007
    Message Count:
    this isin't my thread but im in the exact same situation, i have a 92 thunderbird that has recently recieved a 408w stroker, all forged rotating assembly, edelbrock victor jr heads 210cc, edelbrock super victor efi intake, ford f303 cam, 75mm tb, 60lb injectors, msd 6al ignition, msd dizy, etc...
    its behind an m5r2 standard trany that doesn't like to shift past 6500 (which is my redline) this engine was built for low end torque and im hoping to get just that,
    i was considering twins but now I've decided to go with a single. What turbo would best suit my needs? I'm looking to make full boost as early as possible. CR is at 9:1. I'm guessing its making about 260RWHP nw . I'm hoping to get some where in the neighborhood of 600rwhp. I'm thinking about 18lbs of boost should be about right.
    Car is a daily driver that sees about 2k miles a month. Runs off 93 octane.
  10. turbo23turbo New Member
    Dec 7, 2007
    Message Count:
    Stock block windsors Don't like More than 700 hp! I found this out the hard way Walked the crank. with less than 1000 mile on it
    Sucks I was running 8psi and pump gas tune
    383 with GT-47 88mm 9.80 @137 on radials
    Any way A agree on the single turbo set up. Look at my pic to the left what looks cooler than that :D
  11. 86mustang84 New Member
    Nov 4, 2008
    Message Count:
    im using t3/t4 turbos and they both will push more boost then ill ever need
  12. 4tun8 New Member
    May 1, 2006
    Message Count:
    371
    twin gt35r
  13. 4tun8 New Member
    May 1, 2006
    Message Count:
    371
    t3/t4 is a very vague description of a turbo.
  14. rbonella Member
    Dec 15, 2008
    Message Count:
    432
    18
    turbos
    I agree with all the single turbo guys. I have a 1969 block 351 with a single 77. its a ball bearing turbo from turbonetics and with the cubic inches WE have, boost should start building by 2000 rpms easily. I have a 8.5 compression ratio and only 8 lbs of boost (pump gas street car) and I made 605 hp with over 650 torque @ only 5400 rpms. Keep it simple. you have a lot of cubes so make sure you get enough turbo, but not too much or you will have to wait a while for the fun to kick in!
  15. mrmustangman357 New Member
    Feb 11, 2007
    Message Count:
    770
    a 408 with a single 76 mm, with a .96 a/r should put you solidly in 700 hp easily without needing to turn the wick up.
    a 70 mm, such as the t-70 from master power, with a .90-.96 a/r can be better for street but might be a bit small on the top end. both would be good choices for a single turbo
  16. turbogt Member
    May 1, 2003
    Message Count:
    658
    18
    :lol:
    I too recommend a single t-76, .96 ar...
    you are using the same exhaust gases... A t-76 should actually spool slightly quicker than twin 60-1's....
  17. 4tun8 New Member
    May 1, 2006
    Message Count:
    371
    Single Garrett gt42r IMO. 1.02 backside.
  18. Duece Bigalow New Member
    Nov 21, 2002
    Message Count:
    9
    I think it depends on if it's mostly for street use or track? My first turbo car was Twin T-44's stock block 381, 9.26@139 ran out of fuel and not enough cage to run again
    http://www.youtube.com/watch?v=cifi2CC4
    Then did two T-67's dart block 381
    YouTube - Twin T-67 '92 Mustang 1111whp
    Fun as hell on the street, hurt the motor before taking it to the track
    Then same motor fixed with single 88mm, very boring on the street
    YouTube - Single Turbo Fox Body Mustang. First time at the track
    If goin single, A smaller like 76mm or 88mm with no smaller than a .96 ar, prolly better with a 1.0 ar exhaust housing wouldn't be to laggy at all.
    Twins .81 ar and 60-1's up to t-67's with a 408 would make for a real fast fun street car IMHO!!
Share This Page
