upper control arm mount
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
I read somewhere that the hole for the upper control arm mount is larger than the bolt (14 mm bolt and a 16 mm hole). Can anyone confirm this and if it is true, do any aftermarket arms address this issue? With all of the clunkiness of the rear suspension, I can believe it.
They did that on the sub frame on 03/04 cobras.with our fix its just bolts.honestly they have been doing this a long time.try a bigger bolt in uca bush.caution inside tube you might find bumps thats was what fills the 2mm
