W WEIRDGUYWITHAKNIFE New Member May 10, 2015 23 1 3 Dec 14, 2015 #1 Dec 14, 2015 #1 When switching the plastic lines that break when they are touched to standard rubber vacuum lines will anything be adversly affected? thankyou
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,513 2,864 234 Dublin GA Dec 14, 2015 #2 Dec 14, 2015 #2 WEIRDGUYWITHAKNIFE said: When switching the plastic lines that break when they are touched to standard rubber vacuum lines will anything be adversly affected? thankyou Click to expand... Not a problem, vacuum doesn't care what kind of tube it flows through as long as it doesn't leak or fall apart. Reactions: 1 user
W WEIRDGUYWITHAKNIFE New Member May 10, 2015 23 1 3 Dec 14, 2015 #3 Dec 14, 2015 #3 tHATS WHAT i FIGURED, i THOUGHT THE DIFFERENCE IN DIAMETER MIGHT make a difference, but even then once vacuum is at it's potential it shouln't make a difference thankyou
