F fiveohjunkie New Member Jul 9, 2006 12 0 0 Jan 27, 2007 #1 Jan 27, 2007 #1 Will crane/cobra 1.7rr clear under stock 94-95 gt valve covers? Thanks
final5-0 Mustang Master Apr 6, 2003 6,817 13 79 DFW Texas Jan 27, 2007 #2 Jan 27, 2007 #2 Yes As long as you are talking OEM Cobra RR's The size of Cobra and GT VC's are the same Grady
BlownFiveLiter have car, will race....wait, it doesn't run 15 Year Member Nov 29, 1999 3,134 18 108 Chicagoland Jan 27, 2007 #3 Jan 27, 2007 #3 Also, that holds true only if you're still running factory heads. TFS 1.6 roller rockers wouldn't clear under my factory valvecovers with my TFS heads, so I ended up getting different valvecovers.
F fiveohjunkie New Member Jul 9, 2006 12 0 0 Jan 27, 2007 #4 Jan 27, 2007 #4 Yes they are the crane/ford 1.7rr off of a 93 cobra or 94 lighting. I will be using gt40p heads and ported stock H.O. upper and lower intake.
DDSTANG94 New Member Dec 9, 2006 465 2 0 FRASER, MICHIGAN Jan 27, 2007 #5 Jan 27, 2007 #5 do you guys think they will clear with afr? Ill use a felpro PART # 1645 thick gasket
