Vortech belt routing
Discussion in 'Power Adders' started by 91stangy, Apr 12, 2009.
  1. 91stangy Member
    Jun 12, 2003
    Message Count:
    100
    Ok saw someone had the same problem, trying to put a new serp belt on with everything else stock and cant seem to make it fit. It seems to be maybe 1/4 inch or less short. IS there a way to route to delete some stuff like a/c and smog. If not where do you guys buy your belts and what brand do you use?
  2. blownsn95cobra New Member
    Mar 7, 2009
    Message Count:
    28
    Jeannette
    belt
    what i did for my serp belt problem was unbolt the top power steering pump bolt take it out and loosen the bottom bolt then pull the pws down put the belt on the pulley and pry the pws back in place and bolt it back in place thats how i got mine to work lol i think i used an 84.5 belt or 85inch one of the two
  3. 91stangy Member
    Jun 12, 2003
    Message Count:
    100
    wow that is really short, i have a 90 right now and i am still struggling, im about to sell the blower and go turbo, that should solve all belt length problems.
  4. 91stangy Member
    Jun 12, 2003
    Message Count:
    100
    i see that vortech sells an accessory belt for $70 plus shipping, is this belt any different then the expensive dayco that i buy at any random auto parts store?
  5. blownsn95cobra New Member
    Mar 7, 2009
    Message Count:
    28
    Jeannette
    i guess it depends on what pulleys you got on it i only hve power steering, alt, smoke delete pulley, crank and water pump got ride of my ac and moved the power steering up in its place
  6. blownsn95cobra New Member
    Mar 7, 2009
    Message Count:
    28
    Jeannette
    hell yeah go turbo thats what im doing when i build my 331 or might just go turbo when i get the money for it lol turbo is def the better way to go for sureeee i have had nothing bt problems with the belts and what no with the blower
  7. bdog9seclx New Member
    Dec 22, 2005
    Message Count:
    127
    atl
    all i have is water pump and alternator and crank im not sure how im going to route it any ideas?
  8. bdog9seclx New Member
    Dec 22, 2005
    Message Count:
    127
    atl
    with a 87-93 vortech setup btw
Share This Page
