Vortech install problems on 94 cobra .. Help needed
Discussion in 'Power Adders' started by BPA, Jun 5, 2005.
  1. BPA Founding Member
    Aug 5, 2000
    Message Count:
    161
    S.F. nor cal
    Ok im installing the vortech S trim on my 94 cobra and i ran into a few snags today. im having two problems. The first one is that the smog pump pully is touching the bracket for the abs module.cant find any info in the instal guide about this... The secound problem is the fact that the cobra has coolant hoses going from the water pump down to the oil filter housing not described in the vortech manual. the diagram just shows the hoses from the water pump going up to the pipe along the valve cover. Do i need to just remove both of the oil cooler hoses and lines and/or remove the oil cooler extension housing or just leave it alone and just remove the lines/hoses.So far the install hasnt gone too bad really expet for these small set backs . Hopefully some of you guys ran in to these problems before and can help me out with a few answers id really apreciate it.. Brian
  2. snakebite Founding Member
    Dec 18, 1999
    Message Count:
    1,221
    36
    Hampton Ga
    I removed my oil cooler and now use a fl1a type filter and for the smog pump grind the mount or remove it all together and use a shorter belt.
Share This Page
