Vortech V2 - Bad bearing?
Discussion in 'Power Adders' started by Xcessiv, Mar 29, 2009.
  1. Xcessiv New Member
    Jul 17, 2004
    Message Count:
    208
    Hi there.
    After 2 rebuilds under warranty (leaking seals), here's the sound of my Vortech V2 after a fresh install:
    Vortech V2 - Bad bearing?- Video
    The first video is less than 1 inch away from the blower with 2 high-quality microphones, so the sound is a bit amplified.
    Does it sound bad to you? Before sending the unit to Vortech, I don't remember hearing this "bee sound" mixed with the typical centrifugal sound.
  2. blksq10psi New Member
    Aug 2, 2008
    Message Count:
    117
    mine has been rebuilt twice with in a year of having it, a bad bearing will make a screwtype of whine in your super charger i would check to make sure there is no oil in the front of the charger(intake side), if there is it could be a leaky seal or the impeller rubbing on the case, sometimes after a break in they change sounds i know that my buddys v2 makes a completely diffrent sound than mine (he also has fmic and a 2.89on it) i would just keep your ears peeled for a little bit to see if it gets worse
Share This Page
