Weighed my 91LX convertible Mustang today
Discussion in '2.3L Mustang Talk' started by Anlushac11, Jun 1, 2008.
  1. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    Specs on car:
    1991 LX convertible
    2.3L 4cyl
    T-5
    stock 7.5" rear
    A/C. PS, PB, PW, PDL, less than 1/8 tank of gas.
    Front axle: 1720lbs.
    Rear axle: 1300lbs.
    Total weight: 3020lbs.
    That should figure to about 57% front/43% rear weight distribution.
    I was actually suprised it weighed as little as it did. I was expecting it to be between 3300lbs and 3400lbs.
    I was suprised to see it is so nose heavy. I was also suprised to see the rear end only weighing 100lbs more than my 1980 Mustang Ghia hatchback.
    If you were to add a 5.0L V8 you would add about 100 lbs to front axle.
  2. 5.0Torx Active Member
    Dec 30, 2007
    Message Count:
    256
    26
    interesting numbers...however with a full tank of gas the total weight would be higher and the weight distro wouldnt be so nose heavy.
  3. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    One gallon of gasoline weighs roughly 5.8 to 6.5lbs per gallon depending on specific gravity. At max a full tank adds little over 100 lbs to rear.
Share This Page
