weird CE light.....
Discussion in '1994 - 1995 Specific Tech' started by VIPERn94Five-0, Dec 13, 2003.
  1. went out to lunch with the girlfriend today before she had to go to work and while i was driving home i was slowing down(very slightly) to make the right onto my road and my Check Engine light flipped on...stayed on for like 5 seconds(if even that long) and then went off....didnt come back on for the next couple mins it took to get home.....just wondering if the could mean anything specific???
  2. I would say that a sensor in the throttle body is on it's way out, but you have a semi new TB so I wouldn't think it was that. Can you pull codes and see what you get? I would say either the TB or the o2's. No big deal. The car will still drive perfectly fine.
  3. You need to get a scanner, run the codes, and see what it says.
    If you have a rich or lean condition, it may pop on and off intermittently..
  4. What he said.
    Don't waste time or money guessing, pull the codes and see whats going on.
  5. 99% sure it is your o2 sensors. get the code scanner to be sure though.
  6. Mine did that when it was in 'limp' mode.
    Check your codes ASAP!
