What final (rear end) gear ratio should I go with?
67GTA-FB429 said:
I wish I could run 2600rpm at 70 mph...with my 429 and 3.50s I run 3500 at 70. But then again I have a quater mile C6 with only 3speeds.
That's way to high for 3.50s. You shouldn't be more than about 2600-2800. Even my old 4.11's didn't rev that high. I used to have the formulas to calculate this out, I'll have to look it up at home tonight.
RPM chart for AOD
Edit: This chart is for AOD only, it shows 3rd (1:1) and 4th gear RPMs. If you have a C4 C6 you should just use the 3rd gear portion. If you have a T5 or Tremec the 3rd gear portion is for your 4th gear.
Agree with 68DARKHORSE. The old 3.35 T-5's were marginal in a relativley stock 5.0 mustang making 225 hp at the flywheel, when driven hard. Ford repaired and replaced a lot of these trannys (infamous for third gear problems) over the years. They will last a long time when driven "normally" but with 400hp on tap, some traction and a few powershifts, a long lifespan should not be expected.
