What is the normal vacuum reading for a 5.0?
Discussion in 'Fox 5.0 Tuning' started by Dr Ron, Sep 30, 2006.
  1. Dr Ron New Member
    Nov 13, 2001
    Message Count:
    I think that I may have a vaccumm leak after swaping intake/plenum combo. What is the factory vaccuum reading?
    thanks,
    Ron
  2. Snikt89GT New Member
    Sep 7, 2006
    Message Count:
    266
    A lot of people seem to say that around 15 inches is normal. I tested this on my car today and I got 15-20 inches at idle.
    I think if you are 13-20 you are fine, below 13 is a problem
  3. VG30DE Founding Member
    Sep 17, 2002
    Message Count:
    442
    Depends on your cam and TB. Normal stock should be 14-16
  4. poneypower89 Now everyone in the world will know I wanna bang t
    Dec 6, 2004
    Message Count:
    924
    28
    My car is bone stock save for a vortech blower, and full exhaust. I see 18-19 inches of vaccum at idle.
    when my BOV nipple broke causing a vaccum leak I only seen 11-13... so I would say the 14-16 would be ever so no enough... but thats just me. Maybe it changes with the years 5.0 seeing how ford put slightly different cams in there througout the 5.0 run.
  5. millhouse Founding Member
    May 14, 2002
    Message Count:
    2,074
    46
    13-14 is way low for a stock cam. I'd say normal is probably more along the lines of 18-20+.
    I myself pull 14-15 inches of vacuum at idle with an F-cam and 1.7 rr's.
  6. VG30DE Founding Member
    Sep 17, 2002
    Message Count:
    442
    I pull 8-10 with my comp XE276 lol.. and thats at 1100rpm
  7. coupecop New Member
    Aug 10, 2006
    Message Count:
    167
    how do you check the vac
  8. MARX91 New Member
    Jul 8, 2006
    Message Count:
  9. Muscleford New Member
    Aug 10, 2004
    Message Count:
    29
    I am carbd but am pulling 18" vacuum at idle. It was only 15" until i adjusted the idle mixture. I am running the "B" cam and a 4180C with a 6.5 power valve, lightest secondary spring Holley has, and the primary is jetted two sizes up and the secondary metering plate is drilled two sizes up.
    George
Share This Page
