SuperDust22 said:do they work well
Green 94 5.0 said:rob, the cheaper one is the exact same as what we have just without the datalogging. you can still make changes in the normal way.
Or... just use a laptop. How is that different from how you program the RT?94GTLaserRC said:Well yeah, if you run a long cable, put a computer in your garage, and hook up the cables there. Otherwise, you have to take your unit to your computer, hook it up, make the changes, and reinstall it.
HairyCanary said:Or... just use a laptop. How is that different from how you program the RT?
Dave
Green 94 5.0 said:completely stock, the only benefit you would have is changing fan settings, changing timing, and firming up the shifts if the car is automatic. the base tweecer is $380 and the tweecer r/t is $550.
