what t56s can you use for a swap into a fox. correct me if im wrong but the some camaros had a t56 mated to the lt1. and if so can it be used in a fox with the obvious
necessities bell housing, cross member, and drive shaft?
Best thing to do is buy a kit from D&D Performance. It comes with the correct bellhousing, driveshaft, and cross member. The cross member has brackets attached to it so all you have to do bolt or weld into the frame rails.
