whats causing my surge?? :(
Discussion in 'Fox 5.0 Tuning' started by randyb1976, Jan 3, 2009.
  1. randyb1976 New Member
    Jan 1, 2009
    Message Count:
    22
    hey guys..i am new to fords. i bought a 90 lx...the motor is a 306 with all forged internals, wildly ported e7 heads, edelbrock intakes, 255 gph pump,70 mm tb, headers, x303 cam, roller rockers. i was told that it had 36lb injectors. the problem is at cruising speeds it has a surge that feels like im riding an actual horse! i was told its because of the 36lb injectors that is was getting too much fuel. at idle it hard to tell with the lopey cam but it sounds like its loading up but when i check the plugs they look great. it does have a stock maf. yesterday i got snnoping around and found the injectors are actually stock 19lb thats why the maf is stock. anyways would the 19lb injectors cause this surge at speeds ? possible fuel starvation causing it? what injectors would you reccomend? i plan on getting a little better head so i want something that will work now and then when i get the heads. it doesnt have an adjustable regulator either which is gonna be an upgrade as well. this is my first ford so im lost at trying to figure it all out...any help will be appreciated....thanks
  2. 2002BLGT Well-Known Member
    Dec 18, 2003
    Message Count:
    3,075
    56
    it has a stock 55mm MAF on it ? whats the fuel pressure set at ?
  3. randyb1976 New Member
    Jan 1, 2009
    Message Count:
    22
    i dont knnow the mm of the maf..all i know is that its a stock piece , also dont knnow the fuel pressure..it has a stock regulator on it so i imagine its stock fuel pressure
  4. 2002BLGT Well-Known Member
    Dec 18, 2003
    Message Count:
    3,075
    56
    technically if you have the stock MAF and injectors you shouldnt be getting much surging at all even with the stock MAF and injectors , I would probably pull the distributor and check for play in the shaft .....
  5. randyb1976 New Member
    Jan 1, 2009
    Message Count:
    22
    im going up to 24lb injectors with a matching maf...im told by a local mustang performance shop that with the x303 cam it is common for a surge under 1800 rpms...which is where it surges so i guess its a characteristic of the cam? anyways i am gonna check the distributor also to cover all bases
  6. Lawbreaker5.0 New Member
    Feb 21, 2009
    Message Count:
    537
    go with 24's and matching Maf and through a fuel pressure regulator and maybe a guage on it.
  7. Mustangr Founding Member
    Nov 3, 1999
    Message Count:
    223
    I used to get surging problems well I still do. but when I was running a MAF sensor if you just turn it little tiny turns it can make a big difference but with that set up i would run 24s at 42lbs at the regulator.
  8. fstrbz New Member
    May 13, 2005
    Message Count:
    do a vacuum test on it. I eliminated all my leaks and away went all my surges. The biggest culprit was the brake booster, next was fittings and lines.
  9. Supercharged306 New Member
    Mar 21, 2009
    Message Count:
    9
    Kildalls Racing
    First thing is always check for vacuum leaks. Throw a fuel pressure gauge on it and check the fuel pressure. Check the pump and filter. If you are planning to go to better heads make sure you get new fuel rails and pressure regulator. As far as injectors go 30lbs injectors or 24lbs should be fine. Make sure that if you upgrade don't get cheep junk. 70mm to 80mm throttle body and MAF. You should probably pull the plugs and check to see if they are burning rich or lean (most likely lean).
  10. 90bluegt Founding Member
    Dec 9, 1999
    Message Count:
    597
    With a 306 I would look at going to 30# injectors, with my mods i'm hitting about 95% utilization under full load and I have 24#ers. Also, with everything you are doing to the car you should really look at getting it tuned by either yourself or at a dyno from a reputable tuner.
    This will help with the drivability of the car as it's idle. Then also, you get a tune and then you won't have to worry about getting a fuel pressure regular and you'll know the computer is working off the correct values rather than running from it being tricked.
    Just my .02, but I know at least 10 fox cars that completely changed after getting it tuned, but they got more horse as well.
  11. Certified MD New Member
    Jul 15, 2010
    Message Count:
    I'm having a similar issue - have you got any updates to a solution for your problem??
    My car seems to act fine under WOT, the surging and bucking around occurs only under part throttle & cruising. Seems worse when I'm using accessories like headlights, wipers, A/C, etc... anything that draws amps.
    Anybody got any feeback??
  12. madspeed1 Founding Member
    Mar 22, 2000
    Message Count:
    1,254
    mine does it too, mostly at cruising speed, nothing when on or off throttle. Need to check all vac lines first...of course mine is cammed pretty good and it does come on around 1800 as well
Share This Page
