The carbed 79's had a ton of vacuum, all of which I still have hooked up.
If I was going from efi, you only need a brake booster, a dist vacuum line from the carb ported vacuum tap, and a c4 modulator line if usiing a c4.
If possible, I would try to keep the charcoal cannister. The originals had a vent line from the carb bowls, and a purge line to the intake, managed by a solenoid for the vent and a temp vac switch for the purge.
There was a temp switch controlled vacuum switch for the dist and for the air cleaner also.
