Who uses premium gas in their 2v 4.6?
Discussion in 'SN95 4.6 Talk' started by Ateup, Nov 4, 2009.
  1. Ateup Active Member
    Sep 21, 2009
    Message Count:
    751
    28
    The guy I bought mine from used premium so I have been too. Is there any harm in doing so? Any benefits? The owner's manual said it was designed for regular and using premium isn't recommended. Just wanted some opinions. Thanks in advance.
  2. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,683
    33
    88
    H Town
    Your car is designed to run on 87. You will not benefit, and probably see a decrease in performance if you up to 91-93 octane. Unless you have a timing adjuster, or a custom tune with more timing, stick with 87.
  3. ThePumpkin New Member
    Jan 26, 2009
    Message Count:
    100
    Missouri
    welp. I dont have a 2v 4.6.... but I do run premium from BP.
    When I first bought the car, I ran 87, then switched to 93. I noticed a slight difference in performance (maybe it was just mental) but it sure did feel like an increase in throttle response.. So i've run 93 since.
    I would imagine that the owners manual says no premium because of the low compression, its not needed unless your running some form of forced induction or a stroker kit...
    The difference between "regular" and premium is probably not going to effect your car THAT much as long as its unleaded. ... Thats another story, race gas will foul your 02s in a heartbeat.
    Although,
    Im interested in seeing what have to say about this... i've often wondered in the past if im wasting my money on 93 :shrug:
  4. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,683
    33
    88
    H Town
    yes, your are wasting your money.
  5. ThePumpkin New Member
    Jan 26, 2009
    Message Count:
    100
    Missouri
    Theres the answer. I did notice a HUGE increase in power from a 93 octane tune.
    A good tune will work wonders for any car.
    But i still swear i noticed a little increase in performance when i was 95% stock... I guess it was just mental :rolleyes:
  6. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,683
    33
    88
    H Town
    I would make sure that the car does not have any aftermarket tune on it, first. Detonation can due damage to a motor. If you run 87 and don't hear any detonation, or pinging, you probably have a stock tune and should keep the 87 in the car until you get a custom tune.
  7. ThePumpkin New Member
    Jan 26, 2009
    Message Count:
    100
    Missouri
    I have a custom tune... and oh wait... a 66mm turbo. haha forgot about that.
    I was just refering to when I was mostly stock.
  8. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,683
    33
    88
    H Town
    :D
    Since that is the case, I wouldn't be putting any Mom/Pop Gas in your car. Use the best, Chevron with Techron or Shell. No need to blow a motor over a bad tank of gas. :shrug: You should know that owning a FI car!:nono:
  9. VEE EIGHT New Member
    Apr 27, 2009
    Message Count:
    89
    Texas
    To the OP, only run premium if you've adjusted your timing or have a high-octane tune. I know that you have neither so you're just wasting your money.
  10. 95.0Stang New Member
    Feb 21, 2003
    Message Count:
    544
    Kansas
    I went on a road trip...a 6 hour drive. I always use 91 octane and this would be no different. The first leg of the trip from Topeka to STL I got 27mpg, pretty good for a V8 car right? Then I filled up at a Mobil station in STL with 93 octane, really this was just to do it, I didnt expect any gains at all, but from STL to Indianapolis I got 30.2mpg which shocked the heck out of me! As I was leaving Indy I filled up with 92 octane which is the highest I could find around my hotel, and from Indy to STL I got 28mpg. Stopped at the same Mobil station in STL and filled up with 93 again, and the car did 30.1mpg back home to Topeka. This is MY experience, and why I just always use premium. I am sure there are variables, but honestly I thought these results were really great considering how my car is equiped. Ford said 26mpg HWY on the new car stcker for this car, so to beat that is impressive to me.
    Current mods that COULD effect MPG...
    1. O/R H-Pipe
    2. Magnaflow Catback
    3. Eibach Lowering springs( I figure aerodynamics may change and help)
    Mods that SHOULD lower MPG
    1. Heavier aftermarket Bullitt wheels
    2. Heavier BFG tires in front
    3. Heavier Goodyears to fit the 17x10.5 wheel in the back
    4. Over 100 pounds of luggage in the trunk
    Again this is purely my experience, and not based in science at all, just an FYI type thing!
  11. Pearl02 Member
    Nov 27, 2004
    Message Count:
    496
    Kansas City
    Like everyone else said don't run premium fuel in your car unless it's tune to do so. I work for a gas pipeline company. Our lab runs test for the quality control of all the products we handle. They use what we car a "knock" engine for octane testing. It's just a one cylinder engine bolted to a concrete base. The lab techs are able to advance and retard timing on the fly. Permuim fuel burns at a slower rate than unleaded. More timing can be added for improved power and torque. The testing takes awhile to complete. This is how we determine octane ratings for gas. It's been about 15yrs since I've seen this test run but it hasn't changed. What I have seen is if premuim fuel is ran with not enough timing carbon build up can happen. That can lead to pre ignition which can cause some problems down the road. Pearl02.
  12. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,317
    76
    Fort Wayne, IN
    Use top tier fuel and use an octane that is appropriate for your mods and tune.
    I always run Shell 93 octane and I never let it get below 1/4 tank but I have a FI 4V.
    When I had my old 2001 GT I would use Shell 87 but I would occasionally run higher octanes of Shell gas.
    Top Tier Gasoline
  13. 98COBRA281 Active Member
    Nov 25, 2007
    Message Count:
    1,417
    38
    Port St. Lucie, Florida
    i run 93, because of my tune/compression
    so shell is a pretty good gas? i used mobil for a while, but it sucks, lots of corbon deposites, in my and my dads motor, we pulled my dads heads off a few years ago, and the exhaust ports were filled with a thick coat of carbon
  14. SteedaGT9150 Well-Known Member
    Nov 10, 2004
    Message Count:
    1,994
    27
    58
    Maryland
    i always try and use shell or bp. im not a big fan of anything else, too many horror stories
  15. stangGT97 New Member
    Dec 22, 2004
    Message Count:
    1,405
    32
    Boston area, MA
    When I fill my car up with Shell 87octane in Massachusetts, it runs fantastic. When I get back to NY and have to use gas from ANY station out here, it runs worse. I'm not impressed by the quality of Mobil gasolines, but where I am, my only choices are Hess, Mobil, Sunoco or Stewart's Shops gas, and Mobil is the least awful but still pretty bad.
    Long story short, use 87 on a bone stock GT.
  16. tank_567 Member
    Mar 20, 2007
    Message Count:
    571
    18
    Raleigh, Nc
    I have two tunes, 89 and 93, i saw a 4rwhp difference between the two. I've been running 89 in my car and have been seeing 280-300 to a tank, about the same mpg on the 93 tune.
  17. patman0911 Founding Member
    Jun 5, 2002
    Message Count:
    2,292
    46
    Tuscaloosa, AL
    I run 93 now because i cranked up my base timing with a timing adjuster. I ran 89 before the T/A because I thought I was feeling slight hesitation and pinging with 87, probably due to the 150 degree air and 500% humidity we have down here - oxygen molecules are far and few between in the summer.
    As stated 50 times in this thread already, use 87 unless you've got a real reason not too - pinging or hesitation, or increased timing.
    For what it's worth, I like Chevron with Techron. My car always seems happier when I fill up at the Chevron station :shrug: but that may just be my imagination. In reality, I think any of the major brands are probably fine.
  18. oxfordgt Member
    Apr 30, 2006
    Message Count:
    292
    18
    Clarksville, TN
    This is a simple question to answer. If your not tuned for it then don't run it. Running 93 octane in a car tuned for 87 will cause carbon build up in the combustion chamber. Higher octane fuel burns slower which means that on a stock timing tune you will not burn all of the gas. This is what causes carbon build up and a loss i power.
  19. 02LaserRed2V New Member
    Jul 31, 2004
    Message Count:
    399
    Augusta, GA
    93 and 110 here
    on a bone stock 2V, 87 will be fine.
  20. 302GTS If you need herpes, I'm your man!
    Apr 20, 2009
    Message Count:
    582
    Largo, FL
    As said previously in this thread, it's an absolute waste of money, unless you're running higher timing (like the 5.0 guys!), or you have a tune for anything more than 87 octane. Our cars come from Ford built to run 87, that's why the 5.0's came with 10* BTDC timing, which can be bumped up if you choose to run a higher octane fuel. :nice:
Share This Page
