I have noticed a drop of liquid under my car two time over the past few weeks so I decided to investigate.
It lined up with the back of the transmission so I thought maybe an output shaft seal, etc..., however, that was real dry.
I finally stuck my hand up to the flat surface above the transmission that the shifter comes out of and it has quite a bit of oil sitting on it.
Where would this be leaking from? I am assuming that were the shifter enters the transmission their is some type os seal / gasket. Is this something I can fix from above, or would the transmission need to be lowered??
One last question,how do you check the fluid level in a manual???
