Wont start when warm
Discussion in 'SN95 V6 Mustang Tech' started by Mark G, Apr 16, 2013.
  1. hey i have 97 stang that wont start again after it is warm, i have to let it cool or atleast an hour before it starts again. also if i let it idle for to long it doesnt run well and sometimes i struggle to keep it running.. any ideas?
  2. Hey Mark. First tbing I would check is the air filter. If you have an extremely dirty filter, it will cause starting/running issues while warmed up. If tbe air filter is clean, next thing is check the coolant temp sensor. There are two of them. Tbe one you want to check is the coolant temp sensor that sends info back to the computer. The other temp sensor is a sender for the gauge and has no effect on engine running conditions. Any Check Engine lights? Go to your local Advanced Auto Parts or Autozone (even O'Reilys ) and ask one of the store clerks to have it code checked on.a scanner. They will check for free. While you are at it, might want to pick up a Haynes or Chiltons manual for that car. VERY helpful
  3. Any check engine light?
    My car did something similar and it was the ECT sensor
