E E9_95_GT New Member Nov 18, 2003 45 0 0 Jan 3, 2004 #1 Jan 3, 2004 #1 im just wondering if it would be ok to run 160* Thermostat on my stock 95 5.0L,,or if i should stick with the 180* thermostat??
saleenster Founding Member Aug 18, 2002 2,621 0 47 Vancouver, WA Jan 3, 2004 #2 Jan 3, 2004 #2 E9_95_GT said: im just wondering if it would be ok to run 160* Thermostat on my stock 95 5.0L,,or if i should stick with the 180* thermostat?? Click to expand... Unless you have a speedbrain, or programable computer, then a 160 thermostat will make your car idle a little higher as it thinks its in "warm up" mode. The 180 should work good for your car.
TrophyHead 15 Year Member Mar 18, 2003 1,195 11 49 PA Jan 3, 2004 #3 Jan 3, 2004 #3 Really hot weather you can run a 160. I have a 180 but I live in PA.
YardSpecial New Member Mar 20, 2003 2,664 0 0 MT Jan 3, 2004 #4 Jan 3, 2004 #4 160 is way to cold and it WILL hurt the engine over time ! I run 190+ in the winter and 180 in the summer, PINA YES. Called life.
cardudeusa Founding Member Oct 22, 2002 1,744 4 48 Home of the Florida Gators! Jan 3, 2004 #5 Jan 3, 2004 #5 I stick with a 180 year round, here in Fl its worth it.
