WTB Mustang Coupe(Notchback or GT with Titanium Ground Effects
Discussion in 'Fox WTB/Trade Cars & Parts' started by mach14604, Jan 22, 2010.
Thread Status:
  1. Looking to buy a 1987-1993 Mustang Coupe(Notchback). I am looking for specific colors. I would take Darker Colors such as Black, Blue or Green. Would also accept Silver, White or Gray. I do not want a roller would like to have a full car. Air Conditioning is a must does not have to work but would like to have all the parts there. Manual Transmission is a must. Car needs to drive well. Do not want full out race cars.
    Would also consider a Mustang GT with Titanium Ground Effects not full color. With or without red accent stripe.
    *No red cars.
    In Ohio but willing to ship or drive. Post or PM me.
  2. Also will take Mustang GTS in Tangerine Orange Cars
  3. Got the perfect 87 notch back for you!..it is burnt orange,exterior was fully restored to near flawless,AC compressor is still on the car,i the Evap is still in the heater box and i have the ac condensor,only thing it needs is the compressor to condesor lines, plus the entire drive line only has 2k on it!everything works onthe car,high beam low beam,blinkers,wipers defrost etc. Car runs and drives perfect,i just got a job about 45 miles from my home and need a better car on gas!
    $6500 you can have it!
    the car is also procharged with a front mount inter cooler.
    a short list of all thats on it
    also car has about 2k on it since it was finished
    Fresh 306,block was cleaned up,bored and checked out
    new pistons,rings bearings and gaskets,New oil pump and timing chain/gear set.
    FMS 303b cam,
    GT40 heads with fresh valves,guides seats and matching spring set with port work
    roller rockers
    Moroso aluminum valve covers
    Carb shop holly 750 blow through carb built for this car
    Velocity racing carbhat
    K&N filter
    MSD bllet dist.
    MSD 6al ign.
    MSD blaster coil
    MSD wires
    Procharger P600B charger set at 11psi (have 14lb pully)capable of 20psi
    Front mount intercooler
    turboXS BOV
    Aeromotive boost sensitive reg.
    AN fuel line
    Edelbrock electric fuel pump and filter
    Optima spiral cell bat.
    BBk headers and mid pipe
    Flowmaster catback
    Subframe connectors
    Lakewood drag shocks and struts
    1" lowering drag springs
    8.8 rear with 3:73 rear gears with a all new seals and bearings,rebuilt posi unit
    Weld drag lites with great BFG tires
    Autometer,boost,oil gauges and shift light
    Cervinis hood
    Leather seats out of a 97 GT
    New headlights with clear corners and markers
    new aluminum heater core and hoses (properly installed,no havk job)
    and much more i can even think of
  4. did u find a car yet, got a 88 gt. five speed, blue with silver ground effects. some stuff done to motor. not asking near as much as some ppl. wow. only 4000. w/b if u want details
Thread Status:
