R.J.
If you have no fan coming on, with or with out the a/c, Then your problem is not the water pump or thermostat. Run a jumper wire (power) directly to the fan and see if it works. Check for an open circuit in the coolant temp sensor that screws into the end of the solid black coolant line.
