WTT Stock 97 Cobra 8.8 with Tokico D-Specs for IRS
Discussion in 'SN95 Mustang WTB/Trade Cars & Parts' started by AcidTonic, Sep 25, 2009.
  1. AcidTonic New Member
    Feb 4, 2007
    Message Count:
    I want to swap my stock 97 Cobra's 8.8 with just installed Tokico D-Specs (under 2000miles ago, installed 2 or 3 weeks ago) for an IRS.
    Since we each need a few modified parts to swap I'd prefer to have the cars side by side and do the swap helping each other over a weekend.
    Also my 97 8.8 is slightly shorter than the 99-04 8.8 which means you can fit wider tires.
    My control arm bushings are starting to wear out but otherwise its working fine.
    80K miles on a body in very good condition that 2 years ago had 30K miles. I've used the car as my daily to and from work for a little over 2 years. Diff has had fluid changes and is otherwise stock. I run 245s on the stock rims and the car has never seen a bigger tire. Car is also quite light, easily under 2900lbs so the rear isnt being stressed as much as a stock weight car.
    I have a garage and tools and we can do this over a weekend swaping rears in both cars along with little things required like brakets and tail pipes. I believe the drive shaft just needs a different u joint too.
    Lets trade. I dont care about drag racing and would prefer a better handling daily driver.
    Located just north of detroit michigan. Zip is 48073. Near 13 mile and woodward. Lets swap.
Share This Page
