yet another "combo" question...
Discussion in '1994 - 1995 Specific Tech' started by oosmytoo, Oct 22, 2004.
  1. I will be putting the following combo in my car by the end of next month just wanted to get some of your guys opinions before i do so.
    Trickflow street heat kit
    DSS Pro bullet 331
    FRPP 65mm TB
    C&L 76mm MAF w/inlet pipe
    FRPP 30# injectors
    Kirban AFPR
    28oz balancer and flywheel
    255lph fuel pump
    FRPP roller lifters
    March underdrive pulleys
    PMS tuner
    is there anything i should do differently? also planning on getting a PTK here soon, thats why i chose the C&l because it can easily be recalibrated.
  2. im guessing i must have a pretty descent setup? being that none of my fellow stangers replied! :shrug: :D its all good, mainly what im concerned about is.. will the 30# injectors be too big for now? and should the 76mm MAF be large enough? :shrug:
  3. Sounds like a good setup, especially with the PTK in the mix.
    Some might tell you to get a bigger MAF and T.B. But if you are definitely going to boost your combo, it shouldn't matter as much. If you already have the MAF and T.B., I would stick with them.
