- Sep 22, 2004
- 506
- 0
- 0
ok just picked up my zex kit and filled up the bottle....just wanna make sure i got this right...
on the nmu...the line that says nozzle goes to the nozzle itself...i install one of the jets right before the nozzle and the nozzle to the intake tube
then i get a vaccum hose and run it from the fuel pressure regulator to the fitting on the nmu that says regulator
then i install another jet on the fitting on the nmu that says vaccum and run a vaccum hose from the to the intake..
and then i connect the braided line in the back of the nmu to the bottle...
red is for switch black is for ground and the white wire connects to the green on the tps..
and theres a little black button on the nmu..i turn the ignition on and then press the button while i hold he gas pedal down till a light flashes...then im ready to go....is this all correct if not please help..thanx
