Dyno disappointment!!
:mad:
I finally got my car tuned today.....unfortunately I haven't picked it up yet so I only know what the guy told me on the phone. Working while your car's getting tuned SUCKS!!!
He says 275 rwhp, 312 tq (see signature)....I dont know the a/f yet because I got off the phone fast. I was hoping to get @ least 20 more hp!!
This place works almost exclusively on Mustangs so do you think it's a case of a different Dyno? It's a DynoJet Dynamometer, Ive heard "Mustang Dyno's" show lower #'s, anyone know if they have different names or something? I'll confirm when I get there, but maybe they forgot to put something in the car?? I dont know, but I'm dissatisfied.
wow, i would also have expected more like 300hp and 340tq. there must be something not quite right ... from your sig, it looks like you have the right parts :shrug:
hopefully the graph will tell us something
lol ... i have been working while my motor was being installed, for the last 5 months!
true! I was told by ProM (or whatever they're called now) that they no longer make the 80mm and now it's a 95mm....but the old 80mm used to open to 95mm anyhow, it was just 80 @ the connection?? I took their word for it
Ask Grady or Jt what they think of that.......if the Maf is reading a certain amount of air in.....and the 65mm is only letting it's full capacity in.......I don't know.....may be an issue....but let someone with a better understanding fill in....:shrug: ....I don't know how much is being compensated for......
Will
Post the graph!
Remember this: average horse power moves cars, peak horsepower moves dynos.
What were the goals that you told Ed when he did the cam? Your trq number looks solid but you are correct in that I would have expected more HP. I'd also get a bigger throttle body, at least a 70 to match the intake. How's your FP looking?
Adam
Post the graph!
Adam
I told Ed I was looking for 300rwhp but drivability was key...I've seen these combos get 290+ with a 65mm tb too. I'll post the graph tonight, I'm going to pick the car up in a bit so I'll get the a/f & ask about the fp too.
It's gotta be a missed part or a super conservative tune imo
Just a thought or two on the maf size
For the typical stock block na h/c/i combo ...............
70-75mm is most likely ... physically ... large enough to pass its generated airflow
Of course there is the electrical side of the meter to consider
and
Two things go along with that
accuracy
airflow capability (calibration) ... not being pegged by too much airflow
While that meter is big ... as long as all the above is in place ..........
I would not think the size is an issue here
Now ... About the lower than expected values
Lately ... I've seen a trend to move away from SAE calibration values,
which were more common in the past, to the STANDARD calibration.
Standard cal values are almost always higher and I suspect that is
why we see them more often these days.
Your pull may have been done with SAE :)
Lots of reasons you may be a bit lower but until you talk to the tech ...
We are just spitting into the wind here.
Tell us more when you find out :D
Grady
thanks Grady,
I would have got a 77mm or 80mm MAF if they were easier to get, but I didn't want to settle with the 75mm due to quality issues (or so Ive heard).
Im leaving right now to go, he did call me back and tell me the a/f was 12:1...is that a bit rich? I'll ask about the SAE value too...
