My recommendation is don't do it! Any increase in performance is not even noticeable, and they have been known to cause a failure of the stock oil pump in the Mach 1 motors. Upgrade to a billet oil pump, and you will probably be safe, but then the performance bump isn't worth the expense and labor.Does anyone have any good reccomendations on a underdrive pulley kit for a 04 mach 1 and where to buy? thanks
Ive had several older mustangs and underdrive pulleys worked great on them thanks for warning me about the mach I's I definitley won't put them on it.
Pretty simple really. The oil pump gears run off the crankshaft, underdrive pulley(s) increase the speed that the oil pump gears turn. They seem to work okay on the GT, so I have to assume the oil pump is not set up the same on the two valve motor vs the four valve, but I'm not sure.Can someone tell me how the underdrive pullies destroy the motor due to a failure of the oil pump? I don't see the connection. Does this also apply to the GT motors?
Thanks
