I just installed the latest version of the EEC analyzer. When I try to create a custom MAF file under the MAF tab, EA rounds up the numbers for both the voltage and airflow numbers. The old version did not do this.
Has anyone else experienced this and is there a way fix/ eliminate the rounding of numbers?
Edit: For example if I input 2.7999 for voltage it changes to 2.8. The old version did not change anything. Plus TwEECer accepts the 2.7999 number. I will just have to be just a little bit more mindful when changing the MAF numbers to ensure I put them in the correct column in CalEdit. Now if I input, say 42.3, in the airflow column it changes to say 41.078.
Thanks
Thanks
