interesting... yea, the stock values for the Inj Timing table is 300 for all the cells... i hadn't considering doing what you mentioned--i'll give it a shot, thanks!
Punisher it's been awhile since I worked with the injector timing and I don't recall which one I used, but I used the settings that generated all the same numbers, i.e. 372, for all cells. I think it was "End" and "TDC". Since it generated all the same numbers I figured my settings was correct and I was on the right path since the original J4J1 tune had all 300s in the table in its tune.
The great thing is you can run it as many times as you want to see which is the right one.
so i'm still working on this and have a couple new tunes to try (same scalar modifications, just different Injector Timing table values), but was reviewing the thread and starting thinking about the *single value* (300 in the stock j4j1 injector timing table) thing...
since my cam is split duration (or whatever.. ), i don't know how that would work out, but i figure it's worth a shot.
anyone of you guys running a single number all across the board? if so, how did you calculate that number?
372 for all cells ... You Say
I just looked at mine and all of em are 392
Say Al ... Have you noticed over the past year or so many peeps use
different values a good bit of the time ...
Grady
