bnickel
Can you be more specific about the goals of the project and any limitations or guidelines you need to adhere to?
Horsepower?427 cid 650 hp on motor, it will also have a nitrous system
Drivetrain? 5 spd
Tires type/size? street 275/60 BFG drag radial, track 28x10.5 slick
Target 1/4 ET? 9.50
Target 60 ft times? The best possible times
Cutting, welding OK? absolutley
Is appearance important? yes
Will the front suspension be set up to drive well on the street or made to better transfer weight for drag racing? the car has a rod and custom front suspension
with adjustable coil overs
Do you want a street car that you can safely run at the track? Or a drag car you can safely drive on the street? Sounds silly but there really is a very significant difference.
650hp, 9 second street car? parallel 4 link
