Hipo cam specs:
Part Number C3OZ-6250-C
Application: 63-67 289 HiPo (and 68 service)
Lifter: Mechanical, lash 0.019"
Intake events: open 46* BTC, 12* ATC; close 80* ABC, 26* ABC (not sure what 2nd number means)
Exhaust events: open 94* BBC, 36* BBC; close 36* ATC, 22* BTC
Duration: 310* both I/E
Lobe lift: 0.298" lobe, 0.480" valve
Overlap: 82*
Mark: VE (between distributor gear and first journal
For comparison, the stock 289/302 (65-72) cam shaft specs are:
Part Number C3AZ-6250-V
Application: 65-66 289, 68-72 302
Lifter: Hydraulic
Intake events: open 16* BTC, 40* ATC; close 70* ABC, 8* ABC Exhaust events: open 44* BBC, 1* BBC; close 20* ATC, 27* BTC
Duration: 266*/244* I/E
Lobe lift: 0.230"/0.237" I/E (lobe), 0.360"/0.80" I/E (valve)
Overlap: 36*
Mark: UA (between last lobe and journal)
There seem to be at least two Boss 302 cam specs, DOZZ-6250-A (290* duration, 58* overlap and 0.477" valve lift) and D0ZX-6250-B (324* duration, 114* overlap and 0.589" valve lift). The second is more like the B2 spec I remember. The first seems like a solid lifter version of the standard hydraulic lifter C9OZ-6250-C over-the-counter cam.
I hope this helps. Sorry I don't have the specs for the Le Mans cam. I do have more complete specs for the B302 cams listed above if needed. I'm sorry I don't have the source listed--this was something I have on an Excel spreadsheet from long ago.
Daniel
