g-bar installed
Thanks, yes it was easy to install. Even the welding was straight forward. Hardest part is aligning all the brackets BEFORE welding.
Exhaust??? I have no idea. Car is still a shell with engine in a junker i just bought. Wont have to firgure that out for long time. Hoping others have that figured out before i get there. 68 efi...what are you doing? didnt you say yours was at the exhaust shop now? I am hoping Pete with Reen has some ideas coming.
Mike
Mike
My car is at the body shop/builder right now. I had to go get some braided stainless brake lines made for mine. I just couldn't see putting old worn rubber hoses back on. I was able to snap a couple pictures of it to track the build.
I plan on taking it to the muffler shop when the body work is done. They tell me about a month. It is very tight under there. I really don't see how my guy will be able to go over the axle. I hope he can but I won't hold my breath. On another forum (vintagemustangforum.com) there is a guy that just got done with an install and he was able to use the stock magnaflow kit. It cleared everything without a problem. If I run into a problem it may be because of my Flowmaster 50 series. They are a bit longer than the 40's and leave a little less space back there. I am preparing myself for the bad news to run them under the rear.
I have also seem some pictures of the old Gbar kit where they ran the exhaust over the axle right below the fram rail (on the outside of the shocks). It was a tight squeeze but it looks great. That path depends on how low you want your car.
