My dd is an 02 Explorer Sport trac 4.0 SOHC.
So I was on the highway today and out of nowhere I start to hear this bad ticking sound. Immediatly I checked all the guauges and everything showed normal, so I right away pulled over to the shoulder and got ready to coast and motor started to lose power and then just quit.
I coasted to an exit ramp and got out popped the hood and there was smoke, not steam, coming from around the intake manifold/injectors and out the dipstick tube. I checked the oil and it was a little low but nothing to worry about. Then I checked the coolant because my radiator started leaking a couple days ago and I've been having to add fluid to it about every 100 miles. Well, I can't see any fluid at all in the bottom of the radiator and the overflow is empty. So it must have overheated pretty bad and all the water turned to vapor and the temp gauge did not show it was overheating. But I've popped the hood on some very overheated cars and you can just feel the wave of heat when you pop the hood and everything is hot, but it really didn't seem too hot when I popped the hood.
Well, I added some water, let it cool way off and tried starting it and the motor just spins. Sounds like no compression or anything, just sounds like everything is spinning. I can look down the oil fill tube and see the cam on the passenger side spinnng, but no way of checking the drivers side.
Any ideas?? I'm lost...
