The get rid of the junk in your garage thread!
I have the following:
Seat belts...(all kinds, kinda dirty)
Stock Starter...(dirty, but worked when removed)
T-5 block plate
94-95 stock fogs, brackets, bolts, etc...pretty good condition
Stock overflow bottle
Quarter window interior trim
Broken Edelbrock perfromer RPM intake (needs new rear plenum welded on, bolt holes are broken out)
off road H-pipe (hedman) (5K miles)
BBK Catted H-pipe (8K miles)
Aeromotive Street rod Carb fuel pump...used but works good
ARP main bolts set up for girdle...Have girdle as well. (studs are new, girdle has been used for 4-5K miles)
AFM ashtray switch panel (94-95)
2 dash clocks
Airbag module (under the radio)
2 airbag crash sensors (front of car)
Mach 460 tweeters (still in car, would need to trade for black covers)
Moroso water pump drive
Fox and sn-95 waterpumps (both used)
-8 AN Straight push on hose ends (4 total)
Any engine/tranny bolts...some rusty but there...
all kinds of accessory pullies (one underdrive crank...mostly stock others)
Have ALOT of other stuff...Jog my memory and I ay have it.
Located in Palmdale, Ca
I actually need 2 of the bellhousing to engine block bolts. Lost them and cant figure out where it is, lol. So i wanted an extra anyways so i guess i only need 1 but 2 would be nice. And a few extra pressure plate bolts would help too (dont ask why....) You have those?
Does anyone happen to have any trunk interior. All i need is the little hook that screws in almost right behind the taillights and holds the vertical carpeted piece up, there's one on each side, somehow one of mine disappeared and ford doesn't carry them.....
To go:
2005 stock Honda VTX 1300 pipes, air box, signal covers, and most of a stage 3 jet kit (less 210 main jet).
1 set of fox and sn95 stock headers.
Stock 94-95 t5 with 1 bad synchro that I know of.
1989 AOD stock. Worked when taken out.
Fox body strut tower brace ( no hardware)
Needed:
Stock fogs for a 1994-95
Stock spare tire jack
Any ac parts, have none, will purchase whole set
smog pump lines(hoses and valves)
stock long block
Stock coolant resevoir bracket
stock strut tower brace
wow i got a lot too..
stock head lights, fogs, corners
stock hood
stock H-pipe
stock headers
2 stock TB's
stock upper/lower intake and rails
stock front bumper
2 stock shifters
stock gauges and casing
stock pullies
stock dizzy
stock valve covers
all the 460 stuff
4 silver 97 cobra wheels
stock airbox and MAS
stock front/back calibers
prolly more that i cant think of taking up a whole spot in my garage lol
guessing those are gone since its been a whole year..... :shrug:
