Not a hard swap to tackle at all. I wouldn't pay near that amount to get it done.
Set aside a few hours and knock it out
I've done them on other cars and it isn't difficult, just be careful around gasoline.
This past winter the pump in my Caprice died and since it was 10 degrees out I had the local mechanic do it.
Cost me $125 labor (I already had the part) and it's the same procedure as the Mustang pump, IOW in tank pump.
$600 is way too high.
I changed mine on my 98 GT. My fuel pump went out on me on the way home from the service station. Yep, had a full tank. The hardest part was draining the tank. I cut that rubber grommet and pushed it into the tank and got the gas out through that hole. There is a check valve in the filler neck and you cant get any gas out through it.IF you put a stock pump back in, it just snaps into place.Any1 know how much it cost to change a feul pump?
My friends 98 gt had his go out on him and he got a quote for $600 to fix it. Is that a bad deal?
I don't know so any help to be great.
Also, how hard would it be to do our selves?
