still having problems with the blower and heat soak. got the car back today but still having idle issues. drove car home form builders and it was fine. checked the pipes on the bottom of the intercooler to see if one was hot and the other was cold...that checked out so far cause the blower seal was replaced.
washed the car up because it was a mess. started it up to pull it in the driveway and the idle starts going up to 1500 then down to 500 multiple times. continued to do so as i pulled it into the garage. started to smell rich again. last time it went into limp mode and i had to have it towed into the dealer with the exact same symptoms. we thought it was the boost a pump from kb fuse. however, this time the bap is not in use and its the exact same thing starting.
i hope it dont go into limp mode and rich again so i have to tow it back.
anyway, i pop the hood and everything in the engine bay is burning hot!!!!!!! i couldnt even touch the hood prop! felt the inlet pipe and it was burning, i coculd only touch it for a sec.
why the heck is this happening?
i called the builder and told him. im going to let it cool down for the next day and try to drive it back if it is not in limp again.
what is going on
what is going on
