ill advised
Rrruuuuugh!Chewie quick! hand me the hydrospanner so I can fix the hyper drive on the Falcon!
What causes so much blow-by?
did you check the gasket for the oil filter since this problem happened?
did you check the pcv valve?
did you take the h-pipe off and look for 4 quarts of oil in it???
did you check the hyperfootinating valve?
just drop in an explorer motor and enjoy the extra 80 ponies that come with it.
my money says the muffler bearings seized which caused the hyperfootinating valve to fail thus allowing all the oil to escape through the blinker fluid gaskets.
in dummy talk=no one has a clue what happened.
