1968 DOHC 4.6 Coupe Project
If I had a choice I would rather have brackets welded on the rear end since we welded all the crosmembers in. They designed the kit to be bolted in.
do you plan on welding the brackets in at a later date or just leave it like it is?
i still can't wait to see this car hit the road, i love those flares!!!!!
are you going to paint it yellow and black?
I changed my mind on the taillights. I was going to put a deluxe ribbed taillight panel in and I had cut out the original taillights. Now I have decided to french them in instead. I had put a reproduction taillight panel in our Eleanor project and cut out the original taillight mounting area.
The reproduction taillight mounting area was about 1/4" to big so Brian cut it down and welded studs on it.
Brian welded it back in and now has to grind the welds.
awesome, nice to see it coming along(mine is stalled for about a month or so) what width is that wheel? 8"? maybe its just the tire that makes it look so beefy, I might do bedliner outside of the engine bay, but have heard nightmare stories of it in the engine bay with high heat(which I plan on, turbos put out quite a bit more heat than NA engines and twin turbos are now in my main plans)
p.s. did you weld on the 1/4 panel extensions?
We started lining up the sheet metal. We are having a problem with the bottom of the drivers door sticking out at the bottom. I think we will have to cut it and weld it back up.
We still have to fit the front valance and spoiler
I really like how the flares look. I'm going to have to find an old fender and practise your flaring method. I'm pretty sure if I try that on a car I will warp the fenders beyond use.
I've hardly touched my 67/4.6DOHC project all year. I'm honestly about ready to switch to a 347 just so I can speed it along. I just don't have time to do all of the work these Terminator conversions require!
looking good...keep the updates coming, I'm possibly storing my 4.6L mustang away for a while...although work will continue as always...but slower most likely(since I'm too lazy to drive out to storage all the time to work on it)
