DIY air to air intercooler on Kenne Bell for 92 LX
just wondering what kind of tires your runnin on the back?, i see tires are spinning on video but just love to see exactly what kinda power car makes with a little more room coming out of that spin and hearing what she got. I am a foxbody lover and love to see any innovation with foxbodys what u have built looks like a engineering masterpiece, just love to see that bitch opened up and screaming like holy hell:shrug:
I like the concept, and its definitly a cool idea, but seems like a whole lot of work for the ammount of power your making.
Still, i bet its a blast on the street. Sounds alot like my lightning did
I was never really going for MAX HP with my car just wanted a fun street car and KB's make street cars fun. The A2A project was an attempt to control the high temps caused by KB's. I must admit that I should be making more power, and think I could be with an other than stock cam. I also didn't have the best situation at the dyno for making power. I think I'll have better numbers next spring.
I hear ya, i liked the build and its actually pretty impressive that its still on the stock cam. I didnt realize that when i made the power comment. The air to air thing is cool, that was some serious fab work done that a ton of people(including KB staff) would have ran from.
People do tend to get stuck on numbers too, i think the car would run pretty good at the track, if you could find a way to transfer all that tq to the ground that would be someting
Not the best tires but they're new Falcon FK-452, 265-40-17 with 3:73 gears and 500ftpt the rubber has no chance. I need to address traction soon, I'm thinking 3:27's and NT555R drag radials 275-40
man, this HOLE thread i just finaly read helped me sooooo much, i am going to be doing a NEW build on my 94 gt mustang , the difference.... no air to air, inside BOTH fenders will be air to/water intercoolers in front a cooler from a 2003 to normally keep the fluid cool on the street and a giant 5 gallon ice bucket set up in the trunk for the track. I also plan on using the NEW 3.6 kenne bell as it hits the market
CURRENT NUMBERS and info
94 mustang gt
347 stroker 2.1KB with 15 PSI 2 3/8ths pulley NO SLIP manuel tensioner
car is putting out 500 at the wheels and driven ALOT on the street.
oh and the mickey T drag radials 6-8k miles on street life BARELY chirp 2nd i have videos.... under crappy conditions though
94 mustang gt
Very nice glad to hear you got some ideas here, I'm allways game to help out if I can. I have not heard of this 3.6 KB, is that for a pushrod motor spounds very interesting though. I would like a link to you video.
initial conditions/ 20 mile road trip before 3 passes/ 3000 foot index day between temp and humidiy everyones times were off .5 that day and this was my second pass ever with the car with blown rear control arms
supercharger stang drag Video by John - MySpace Video
Since my manifolds are off I thought I would take some pics of the inside of the inside of intake where the 3" pipe was welded. When I did this project the first time I never got pics of these transitions.
Here is the inside of the discharge side going into the GT-40 lower manifold.
Here is the bypass flange that I cut and rewelded backwards to fit in that very tight spot.
Here is the piece of angle I cut out of the original KB bypass flange.
Inside of the drivers side manifold to pipe transition. After the welding I did alot of blending and grinding to make the transition smooth.
I just want to give and update as my car is up and running for the spring. I'm now seeing 16.5 to 17 psi with my 8 rib pulley setup and smaller 2.5" KB pulley. I'm using one 9gph meth nozzle and hope to get a dyno run with my new setup soon. I just heard from another who saw this thread here and used it to build his own A2A congratulations to jj89fox I hope he will post up pics and results.
