Ok Last night I went to pick up my new rearend for my 95 mustang. In this guys garage He had a 1984 Mustang predator built right in my home town of topeka ks. He also had a 1984 GT350 and a 1979 Mustang pace car. Now im kind of a mustang guru but until last night I had never heard of a mustang predator. I have heard of the other two. So I got home and searched it. They in fact were made right in Topeka KS. THere were only 125 of them made in 1984 and his build number stamped on his was 119. Here is some info on these cars.
SOLOMON AMERICAN
TOPEKA, KS
1984 PREDATOR G.T. 302
INCLUDES ALL STANDARD AND SOME FACTORY OPTION FEATURES
OF THE MUSTANG GT LISTED ON FORD WINDOW STICKER - PLUS:
- Predator high performance 302 4V engine dress up
- Monte Carlo reinforcing bar which adds strength under severe driving conditions
- NASCAR locking hood pin set
- Functional hood scoop
- Pace car type air dam
- Four point tubular steel rollbar which adds strength to the body
- Round walnut gear shift knob
- Eight spoke aluminum 0 offset wheels
- Three bar chrome spinners
- 235/60x14 inch RWL B.F. Goodrich radial TA's for a wider stance, improved handling and performance
- Rocker panel identification stripes
- Body colored rubber protective trim
- Aluminum sport shade
- Tail light trim tape
- American flag decal on hood
- Modification serial number on inner fender
- Detailed: gas tank, fender wells, under hood, rear brake drums, etc.
DIMENSIONS GEARBOX
Wheelbase, Inches: 100.4 Borg-Warner T-5 - 5-speed ratios
Tread Fr. and Rr., In.: 56.6/57 OD: 0.72:1
Length, Overall Inches: 179.1 4TH: 1.00:1
Width, Inches: 69.1 3RD: 1.34:1
Height, Inches: 51.9 2ND: 1.88:1
1ST: 2.95:1
SPECIFICATIONS
Curb Weight, lbs.: (EST) 285.3 CLUTCH
Tire Size: 235/60x14 Ford, Heavy Duty, Diameter 10.0 in.
Brakes: Front Disc, Special drum rear
Engine Type: 302 ci, OHV V-8 OPTIONAL AUTOMATIC TRANSMISSION**
Compression Ratio: 8.3:1 Make and Model: Ford Automatic Overdrive
BHP 3800 RPM: (EST) 223 Type: Vacuum controlled shifting with torque converter multiplication
Torque 2400 RPM: (EST) 287 ft/lbs Number of Speeds: 4 & 1 Reverse
Weight Distribution %: 57/43
Construction: Steel, Monocoque REAR AXLE
Ford: 7-1/2 inch
ENGINE Raio Standard: 3.08
Type: V8 High Perf. (Special) Traction Lock Standard Equipment
Fuel: Pemium unleaded only
Capacity: 302 C.I.D. SUSPENSION
Firing Order: 1.3.7.2.6.5.4.8 Front, independent MacPherson Struts, coil springs, anti-roll bar standard equipment. Rear 4-link live axle coil springs, Quadra shocks, anti-roll bar.
Bore: 4.00 inches
Stroke: 3.00 inches BRAKES
H.P. (SAE Net): (EST) 223 @ 3800 Power Assist Front Disc: 10.0 in. diameter, ventilated
Torque (SAE Net): (EST) 287 @ 2400 Rear Drums: 9.0 in x 1.75 in.
Oil Sump: Double Valley steel
Cylinder Block: Cast Iron TIRES
Cylinder Heads: Cast Iron 235/60X14.0 inches. Raised white letter radial performance tread design.
Intake Manifold: Cast Iron
Crankshaft: Cast Iron, supported in five main bearing with external counter balance WHEELS
Main Bearings in Diameter: 2.25 inches Cast Aluminum: 14 in. - 6-1/2 in. rim
Rod Bearing Diameter: 2.123 inches
Valve Operation: Push rod, from cam in block CAPACITIES
Valve Diameter: Intel 1.78 inches, Exhaust 1.47 inches Radiator: 13.4 Quarts
Valve Springs: 1 & 1 damper spring per valve Engine: 5 Quarts (with filter)
Valve Lift: 0.450 inches Fuel: 15.4 Gallons
Carburetor: Holley, 4-bbl, 600 CFM
BODY STYLE
IGNITION Fastback or convertible, four passenger. Hood with functional air scoop and racing type positive locking devices. 4-point fastback tubular show bar in coupe or 6-point 3: tubular show bar in conversions.
Electronic breaker less distributor centrifugal advance
Voltage: 12V
Coil: Ford
Alternator: Ford
Here is a link to one so all of you who have never heard of one can take a look.
1984 Ford Mustang Predator GT For Sale, Classic Ford Mustang For Sale By Owner
Thought this was too cool not to share so there you go..... Enjoy
SOLOMON AMERICAN
TOPEKA, KS
DIMENSIONS GEARBOX
1ST: 2.95:1
SPECIFICATIONS
Ford: 7-1/2 inch
Bore: 4.00 inches
BODY STYLE
Voltage: 12V
Coil: Ford
Alternator: Ford
