I should have given more details about the 4 spark tables
but
between being busy
and
all my notes on a different pc I don't have access to now
I won't go into specifics as I have kinda forgot some of that stuff
and
I won't take a chance of giving misleading info
if
I can't be sure of my facts
The jest of it is
I only use one of the four spark tables to tune with which is the base table
Altitude, Borderline, and MBT Tables I took out of the picture
I killed the three tables by using the value of 55 in all cells
Tip: before trying such a radical change save your file to a different name
then
You can easily go back if you wannna
Also ... go easy on the fuel adjustments if you don't have a wb :Word:
You have no way to know where you are now and after changes
Grady
but
between being busy
and
and
if
The jest of it is
then
Grady
