What's the best choice for upper/lower control arms?
Mustang5L5 may very well correct me on this one but when I swapped my stock UCAs last year the kit I bought from MM (with the same part number as you listed) included the axel bushings - I believe...
However, unless your upper control arm axel bushings have been replaced within say four-five years I recommend you to change the bushings anyway.
The replacement bushings from MM are much better than the original ones as far as fox bodies are concerned.
Regarding the MM tool, if you cant rent it then buy it - you'll understand why when you are under there doing the swap!
My UCAs are Ford Racing. I'm not sure if they come with axle bushings. Yeah I suppose it would probably be a good idea then to have those replaced as well.
the mm ones these days dont come with the axle bushings, you buy them separate. so in other words if you were to do your uppers from mm you would need the 130 dollar set of arms, ( comes with one side bushing) then the axle bushings, then the tool.
i know someone that knows how to do the upper bushings so im just gonna get the moog upper bushing kit. 2 of them for both arms is about 80 bucks.
Dont waste your money on the tool, just use a drill on the rubber and once that is out cut a slit in the metal casing, then spray it with PB and it will come out. Myne took about 30 minuts with this method
lol!!!
I just called Llovio Ford in South Gate to see if they have the brand new bolts for control arms. He found them for the lowers, and then said that my car doesn't have upper control arms...? That these cars never had them
from the factory. Am I missing something here lol? I kind of chuckled a little
bit. So anyway, I'm assuming the bolts for the lowers are the same as those for the uppers? Correct me if I'm
wrong.
lol!!!
wrong.
lots of stupid parts guys out there! they'll argue with you about your own car, haha. I just say ok, no point trying to do anything else
Don't buy the bolts and nuts from 50resto. I almost ordered them for my build and for four bolts and nuts it was like 52 bucks plus 14.95 shipping. I went to my bolt supplier and got 4 hardened bolts, nuts and washers for 5.80 out the door. They are 10.9 hardened bolts. 12mm metric thread.
yea thats pretty much the way ive done them... they sent me a tool for the IRS bushings for a cobra before i tried it, broke it and got out my drill...
