2 bolts hold it to the firewall along with a retaining plate under the dash. Easy enough just trace it and use your mind man.
you dont have to remove the dash. Come from underneath it. you will have to take the gauge cluster off.
Its not plastic its aluminum just pop it off with a skrewdriver.
Do you have the tranny harness hooked in and the nuetral safty switch?
silly question, but did you plug in the computer
it should still prime the pump, just wont start. I didnt follow your entire swap but I thought I remember you posting something about using harnesses from different cars. I would say it is time to retrace all the connections and grounds.
